Steve, Let's take it from the top: The white-wire goes to the top of the starter switch on the right-hand side of the top two screws...that is the copper wire coil--the white then connects to the other end of the generator on the F{field] or bottom screw The green wire goes to the Field/lite screw or the next screw directly under where the white wire goes. The one end of the green wire comes out near the instrument panel for the rear lights, the other end near the wire harness and terminates @ the top of the fan bracket for the front lights. The blue wire goes to the "Ign" screw through the wire harness and connects to the negative side of the coil [if you have a 6 volt]. Then a black wire coming from the wire-harness attaches to the left screw on the cut-out-relay [opposite the "bat" side"} and then makes a home-run to the "A"-side of the generator..top screw. Then another black wire goes from the "bat" side of the Cut-out-relay back up to the right [back-side] of the Ammeter. Then on the same right-side of the back of the Ammeter, another black wire goes from this screw to the "Bat" screw on the back of the Ignition Switch...in between this last connection is where your fuse should reside. Finally, from the starter where the negative wire from battery connects, your red wire goes from here back through the instrument panel and connects to the left back side of the ammeter, opposite where two black wires connect. Hope this helps... If you have a 12 volt or voltage regulator, then Clooney or John T can help you...I just completely rewired the MT and these guys helped my immensely... good luck
