Another 70 diesel confusion...
TB SCOTT
05-06-2003 08:19:41
Back to the 70 diesel...I know most of the ones i have seen do not have an air intake precleaner, but the ones that did had the inlet added to the front and to the left of muffler. This 70 I just got has the inlet/precleaner assy beside the muffler. The parts book doesn't show it this way. any ideas???
Blksmok
05-06-2003 08:29:57
 Re: another 70 diesel confusion... in reply to TB SCOTT, 05-06-2003 08:19:41
TB..... you're right in that most 70D's did not not have a precleaner. When they did, the hole for it was in the nose cone not the hood. A 720D with precleaner has the hole in the hood. It may be that someone had a 720D donor tractor that it's parts ended up on your 70. What's the s/n of your 70?? I recently saw a 70 that had a steering console and all the sheet metal from a 730. Had to check the s/n to confirm it was a 70. Later.
70D
05-06-2003 12:22:51
 Re: Re: another 70 diesel confusion... in reply to Blksmok, 05-06-2003 08:29:57
SN#7013837 My 70d has the precleaner across from the muffler It has been there as long as I can remeber not saying that dad did'nt have change when it was new 70D
F-I-T
05-06-2003 14:36:18
 Re: Re: Re: another 70 diesel confusion... in reply to 70D, 05-06-2003 12:22:51
70D:
Are you SURE it's right across from the muffler ? The piping sold to put the air stack on a 70D was very different from the -20 series. The top of the aircleaner was re-designed on the 720's to accept the stack which placed it across from the muffler. Not saying it couldn't be done, but using 720 parts would be the easiest way.
If you have a 70D parts book look on page 35-2.
Frank
70D
05-06-2003 15:41:45
 Re: Re: Re: Re: another 70 diesel confusion... in reply to F-I-T, 05-06-2003 14:36:18
I have to work the next five days but after I'm going to get pic of it and post it. I don't know if you remeber me saying that dad had it overhaul in the early 60 could have been transform then I was only a little s--t so could'nt say for sure and Dads driving tractors up in the big sky. Thanks as always 70D
F-I-T
05-06-2003 08:23:39
TB:
Are you sure you don't have a 720D ? The serial number plate would start "70..." to be a '70'. With all the 720 type things you are finding, either you have a 720 with some 70 tin, or a 70D with alot of 720 parts.
On a 70 the optional top-mounted air intake is just ahead of the muffler.
Frank-in-Tallahassee
70D // 855
