How to remove broken idle adjusting needle on 520 ?
Tyler-MO
05-05-2003 20:37:48
I just got finished replacing the intake manifold gasket on my 520 LP and noticed that one of the idle adjusting screws (the book says needles) is broken off flush with the cast housing. Does anyone have any ideas about removing the old one and replacing it? Oh yeah, the gasoline and LP are the same as far as the idle needle is concerned! The tractor idles a little sparadic so I'm thinking this could be my problem. Thanks
Tyler in MO
Earl S.
05-05-2003 21:47:53
 Re: How to remove broken idle adjusting needle on 520 ? in reply to Tyler-MO, 05-05-2003 20:37:48
Take carb off heat needle with a torch until it just starts to turn a little in color (STOP). Let it cool completely. I have a dremel with a fine abrasive blade .I cut a screw driver slot in the broken end of needle.With a little luck it will back out. If not go through the heat & cool add a little 3in one oil and heat and cool. (PATIENCE) It has never failed me. Earl In Illinois
