70 update and 50 carb question
Murf
05-05-2003 13:26:29
I got my 70 running I took all the advise from this board but just put one bearing in anyway Thanks guys I did decide to scedule a complete overhaul this winter to take care of all the various leaks and to check all the areas out completely. Now my 50 with duplex carb floods the cylinders when its shut off, I picked up a carb overhual kit and a new float but don't really know where to start other than removal. Any help would as always be greatly welcomed.
John Van Valkenburgh
05-06-2003 00:40:14
 Re: 70 update and 50 carb question in reply to Murf, 05-05-2003 13:26:29
The duplex carb on the 50 is pretty straightforward in it's design. The part thats giving you problems is the float-needle-seat assy.
First make sure your float "floats". If it leaks and gets gas inside it then it will sink to the bottom of the chamber and allow gas to flood the engine.
If the float looks good and does not bind on its pivot you should be able to replace the needle and seat and simply make sure the float is "set" properly. I believe the float should be set so that the needle is closed when the float is even with the carb seam. The float is adjusted by bending the tab which contacts the needle valve. I usually blow into the gas inlet and move the float up to make sure the needle is seating properly.
The parts found in carb kits vary somewhat. Often there will be a new throttle shaft and bushings. If your throttle shaft is worn it will likely leak air and cause uneven running. If you choose to replace the throttle shaft and bushings you may need to ream the new bushings to fit the shaft. Make sure the throttle moves freely.
Also make sure the choke is operating properly. Sometimes that little spring breaks and the butterfly plates won't open.
Best of luck,
John
