I confess I haven't driven one of those older Fords. Oldest Ford I drove was a 4000 ('67 model?? can't remember) with the select-o-speed powershift. It was great on a JD 1209 MoCo especially with shift on the go. It was a diesel with supposedly 43 hp. The power steering was a joke, so my dad took it off...steered about the same (which was a lot better than our '52 JD G). The brakes sucked. Could not stop or hold much of anything. Was very light tractor, so '52 JD G would always out pull it. Many claimed the select-o-speed to be a piece of crap, but in the 20 years my dad had his the transmission was adjusted once...no problems. It was used and sometimes hard, but not for tillage. We used the 4000 on a JD 24T with 8x16' hay racks on some pretty steep hills. Couldn't always fill the hayracks full, and had to be careful were one turned less the baler and rack push you. I've driven other brand of older tractors such as oliver super 77, some old Massy Harris (I forget the model), JD As, JD G, Farmall B, Farmall super H, AC WDs, AC WD45s, and probably a few other smaller tractors (and a whole range of larger and slightly newer ones too). Each was pretty ok in my books. All of them beat JDs hand clutch when it came to backing 4 wheel wagons. The JDs usually could pull more, but was usually due to more weight for the base unit rather than horse power. The all have their weak points and some are more suited for particular jobs than others. Lot of the time it really had to do with the equipment you had...if it was designed to work with the brand tractor you were using it usually worked ok or even well. I choose JD because by and large I feel it is built to be more "user friendly" and seems to last longer (course that really has to do more with the users/abusers than the brand). To be truthful, my favorite "little tractor" was the AC WD45 (old style). And some day I will get one and it will have to share the same shed space as my JDs.
