How loose is too loose for H main bearings???
Denny Foster
05-04-2003 17:45:58
I have 2 H tractors and they both have looseness in the main bearings noticable on the flywheel side probably 0.10 up and down. I hate to spend the $$$ to replace them if this is acceptable.
Thanks
Denny
Denny Foster
05-05-2003 03:08:46
 Re: How loose is too loose for H main bearings??? in reply to Denny Foster, 05-04-2003 17:45:58
Thanks Clooney, I have got two H's strown apart and trying to make the best out of two. both both have worn main bearings.
Clooney
05-04-2003 18:42:24
Denny, .010" is on the high side. If it's already apart now would be the time to replace them. The tractor will run at .010" but you are asking for an oil leak as well as the possibility of some noise. There is no room for future wear & it will only get worse....
