Coils
Blake
05-04-2003 15:37:53
In a magneto Wico X how much more hotter is a hot coil from a regular coil and does it make a tractor crank easier?
Clooney
05-04-2003 16:28:36
 Re: coils in reply to Blake , 05-04-2003 15:37:53
Blake, that high output Wico X coil really needs to be used with the high output magnetic rotor to show much gain. On a normal compression stock engine you won't see any difference. The ignition secondary will only build high enough to jump the plug gap so any extra won't do much for starting. ~About 2 years ago I tried a back to back using a standard X coil then a high output coil [test tractor was stock well tuned A] while the tractor was hooked to a Dyno. The high output coil actually showed a very slight loss in hp. The back to back time was about 10 minutes so I chalked the loss up to heat soaking during that 10 minutes.
John T
05-04-2003 16:11:35
Blake, a so called "Hot Coil" will not make the tractor crank (turn over) any easier. Supposedly (if the advertisements mean anything), its manufactured with better materials and insulations which makes it more efficient. HOWEVER, it will not fire at any higher "voltage" than the regular coil, as thats primarily a function of the plugs gap (distance) and the medium (fuel and compression) in which it fires. I still use them when I rebuild my mags though, since they arent all that much more expensive and are (hopefully at least) more efficient.
If a coil has better magnetic materials and the wire is wound more dense (thin but good insulation) it can certainly improve the mutual magnetic coupling and transformer action and transfer more energy across (primary to secondary) while loosing less energy to heat, so it is possible for one coil to be better than another. If less energy is lost in the transfer (primary to secondary) it would be possible that a superior coil discharges more energy across the plugs gap, and even if it discharges at the same voltage as the cheaper coil (as explained above) it would be at slightly higher current to better ignite the fuel charge. Therefore (assuming the hot coil is actually more efficient) it might cause the tractor to start and run slightly better, regardless if enough better to be very noticeable.
BOTOTM LINE assuming they are more efficient, it might help slightly in starting, cuz more energy (volts times amps) is discharged across the plugs gap when they fire.
John T Nordhoff in Indiana
