37 A GOVERNERS
GOT THE FEVER
05-04-2003 13:56:26
I REAJUSTED THE THROTTEL LIKE ITS SUPOSED TO BE BUT GOVERNERS STILL DIDNT WORK I PULLED THE COVER OFF OF THE HOUSING AND DIDNT SEE ANY PROBLEMS PLEASE HELP THANKS
Clooney
05-04-2003 15:23:04
 Re: 37 A GOVERNERS in reply to GOT THE FEVER , 05-04-2003 13:56:26
GTF, please explain you problem farther. What does it do or not do? What happens when you move the hand throttle? Does all the linkage move smoothly & to both idle & wide open throttle?
GOT THE FEVER
05-04-2003 16:33:39
 Re: Re: 37 A GOVERNERS in reply to Clooney , 05-04-2003 15:23:04
HI CLOONEY I BROKE THE THROTTEL ROD LAST WEEK WHILE AJUSTING RPM S EVERY THING MOVES SMOTHLEY WHEN THE THROTTEL IS MOVED FAWARD IT GOES WIDE OPEN WHERE IT SHOULD BE ONLY BOUT 1/4 AND WHEN LOAD IS APPLIED IT JUST SLOWES DOWN
GOT THE FEVER
05-04-2003 18:44:12
 Re: Re: Re: 37 A GOVERNERS in reply to GOT THE FEVER , 05-04-2003 16:33:39
ALSO THE GOVERNER CONTROL ARM DID MOVE BACK AND FORTH WHEN IDELING AND WHEN THE CLUTCH WAS ENGAGED NO LOAD BUT NOW IT DOSENT CHANGE ENGINE SOUND OR RPM .IT WAS TURNING AROUND 800 RPM FULL THROTTEL AND HAD GOOD GOVERNER RESPONCE BEFORE I MESSED WITH IT .NOW IT WILL TURN OVER 1400 RPM+ AND THE GOVERNERS DONT SEEM TO WORK AT ALL.
