D Won't start (Hand Crank)
Dave Brown
01-09-2004 18:16:49
How do I get this thing to fire? Here is what I have been doing. Choke off (now that I figured it out, Dxlt 63) Fuel lever to F position (no fuel in G position, Compression valves open, In nuetral, Clutch lever all the way back, then turn the flywheel away!!!
This motor has been rebuilt, and compression is high (my god is it high) I go it to fire for the first time but I did not adjust the choke to on. I did take the plugs out and sand blasted them, they were dry and black.
Any Suggestions??? Thanks
Dave Brown
Mark
01-10-2004 09:19:15
 Re: D Won't start (Hand Crank) in reply to Dave Brown, 01-09-2004 18:16:49
The reason the plug wires were crossed is that the mag has been removed and installed 180 degrees off. It should still start. If you changed the wires without changing the mag, it won't start, but only pop. Try putting the wires back the way they were if you changed them, maybe find a buddy to pull you.
Kenny W.
01-10-2004 06:28:37
Dave, I had a similar experience when I tried to start my '38 D for the first time. Tried to start it like it was a Hit-n-Miss engine...almost gave me a heart attack and blisters on my hands that took two weeks to heal...it never fired once. While recovering, I checked out the archives on this discussion board and found some advice that I try to share with anyone who is having trouble hand-starting these marvelous machines. With the petcocks open and the choke closed, rotate the flywheel until compression stroke begins in #1 cylinder (air starts coming out the petcock) stop rotating the flywheel at that point and rock it back and forth like a pumping action 3 or 4 times without actually completing the compression stroke. I watch for a gas mist from the petcock (sometimes it takes a few extra times pumping the flywheel). Then I ease the flywheel on over past ignition and the old girl fires off almost every time. Don't forget to re-open the choke.
This discussion board probably saved my life or my "D" from the scrap yard.
Kenny
Huntsville, AL
Starting Article
01-10-2004 07:41:25
 Re: Re: D Won't start (Hand Crank) in reply to Kenny W., 01-10-2004 06:28:37
Here is the link to that life saving article by clooney. I printed that when I first saw it posted here and nailed it to my garage wall. Sometimes simple things in life are the most useful. Sure made my life easier.
Clooney
01-10-2004 06:25:57
Dave, with a DLTX 63 carb you want to use the choke when starting [at least for the first few flywheel revolutions]..
~Not all D's start the same way using the same technique so try different things until yours starts good.
~Probably a good place to start is: open the fuel valve,, set the choke closed ,, throttle lever almost all the way back to idle,, open the petcocks,, slowly turn the flywheel in the starting direction,, if [when] raw fuel comes out the petcocks open the choke & open the throttle a little more..
~If it still won't start, try closing the choke to 1/2-3/4 closed again..
~You might also try different load needle settings 2-1/2 turns out from seated seems to work good for starting on a cold older D..[put the load needle back after starting]
~If you are having trouble turning that big pistoned D you might want to make sure you have the big bore petcocks in it. Small petcocks will really make it hard to turn over..
~Remember you don't have to fight that flywheel, all you need to do is get it over the compression stroke,, you don't have to turn it fast or like a 16 year old kid.. Just turn it slowly & get it over TDC compression.. Most of mine will start one handed by just rocking the flywheel over center.. You could have a heart attack if you try to power that 500 cubic inch engine over at a fast flywheel spin rate..
~Remember on a cold D when all else fails-- a John Deere H & a flat belt is the desired starting procedure [a good excuse to buy an H]...
[email protected]
Billy
01-10-2004 05:22:11
Are you sure that every thing is in time , you have fire at the correct time. Set the idle jet on carb 1 3/4 turns open from closed position. they can be contrary. Don't get the radiator boiling by hand cranking the darn thing. If I have much trouble starting by hand go get another tractor & a flat belt & belt them together,then you can maybe see the problem. Don't forget to twist belt for the correct rotation of motor. The setting on carb is just a starting place. Billy
Dave Brown
01-10-2004 07:20:58
 Re: Re: D Won't start (Hand Crank) in reply to Billy, 01-10-2004 05:22:11
Thanks Guys, I was starting to think screw it, I'll find a starter hit for it. I'll give your alls advise a try and let you know.
One thing I did notice is that the guy who had the tractor had the plug wires crossed according to the manual.
Thanks
