John Deere Model B Transmission Problems
Kevin
05-03-2003 21:41:05
third party image
I was having trouble with the transmission in this tractor, so I ripped it down and replaces both bearings on the top shaft(#6 & #15 in the pic above). I also replace one of the shifter & fork assemblies that was broke. I checked everything else out the best I could. I adjusted all the shifting forks like the service manual described. Put it all back together and tried it and it worked for half the day and then it started to get a grinding sound in the transmission like two gears rubbing against one another. I ripped it back down and can not for the life of me find what the problem could be. The service manual is pretty much useless for the most part. The only thing I can see is the upper shaft (#11 in the pic above) has alot of end play and movement where it seats in the gear & shaft(#13 in the pic above), this is a split shaft. Are these two shafts supposed to have this play where they come together? Is there any way to tighten these shafts up? I can not see any possible way to tighten them from either side of the case. I believe this looseness between these shafts are causing all of my problems, like when your working it and the #11 shaft gets torque on it I believe it raises up and ends up bending the rods that the shifter & fork assemlies slide one. Can anyone help, I'm open to all and any suggestions.
Thanks to all that reply
ed b
05-04-2003 20:23:55
 Re: John Deere Model B Transmission Problems in reply to Kevin, 05-03-2003 21:41:05
is #13 shaft worn are the bearings seated correctly are they the right bearings what were the problems that made you take it apart make shur that everything is installed right and tight is the #12 bearing worn ed b
Kevin
05-04-2003 21:52:23
 Re: Re: John Deere Model B Transmission Problems in reply to ed b, 05-04-2003 20:23:55
Thanks for your help, I found the problem. The shaft(#11 on my pic) had the nipple broke off that went into the bearing inside of shaft/gear(#13 on my pic). So know I have to try and find a new shaft(#11). Thanks again for responding.
cole in mo
05-04-2003 00:28:51
Kevin, there should not be any end play in shafts #11 or #13. and there should not be any movement of shaft 11 inside of shaft 13. are you sure that both snap rings #5 are in place? and that bearing #12 is installed inside shaft 13? also check to make sure you have all the hardware installed correctly on the end of shaft 13. let us know what ya find.
Kevin
05-04-2003 21:53:37
 Re: Re: John Deere Model B Transmission Problems in reply to cole in mo, 05-04-2003 00:28:51
