JD 110 Regulator Wiring
Kevin Phillips
05-03-2003 07:50:20
Sorry. Posted under the wrong title the first time.
I need a wiring diagram for a JD110 with a delco remy starter-generator (#1101970). This tractor has been worked on several times and is quite likely wired incorrectly.
Newly rebuilt engine started fine. After running for 30 minutes I turned it off and now it will not start. The GEN light stayed on continuously while running.
growling noise from VR when trying to restart. Removed VR - no burned points - reinstalled and now starter turns over, but will not start. Weak spark.
12.86V at battery and VR B terminal. 6-8V max at coil. Everything is wired through the VR.
I'd like to confirm correct wiring and then learn how to test VR.
Thanks,
Kevin
Willie J
05-04-2003 06:31:44
 Re: JD 110 Regulator Wiring in reply to Kevin Phillips, 05-03-2003 07:50:20
Kevin
noticed your questions about your 110. just like the big rigs, go to your local green& yellow dealer & order the books. both operators & shop manuals. mine were about 10 bucks each, worth their weight in gold.
Kevin Phillips
05-03-2003 12:26:53
Well -
I've got the Deere running again. Two items needed attention. First I polarized the generator and second replaced the plug.
Still need to be sure I have the wiring right for the VR.
Kevin
