JD 110 Trans Axle
Kevin Phillips
05-03-2003 07:48:50
I need a wiring diagram for a JD110 with a delco remy starter-generator (#1101970). This tractor has been worked on several times and is quite likely wired incorrectly.
Newly rebuilt engine started fine. After running for 30 minutes I turned it off and now it will not start. The GEN light stayed on continuously while running.
growling noise from VR when trying to restart. Removed VR - no burned points - reinstalled and now starter turns over, but will not start. Weak spark.
12.86V at battery and VR B terminal. 6-8V max at coil. Everything is wired through the VR.
I'd like to confirm correct wiring and then learn how to test VR.
Thanks,
Kevin
