Help me please
R smith
05-03-2003 07:20:06
How do I get the hood off of a 1942 JD B,do I have to pull the steering shaft out of the box??New to the tractor scene just trying to get the thing apart so I can start on repairs.Thanks to all that answer.R Smith
R Smith
05-04-2003 06:14:18
 Re: Help me please in reply to R smith, 05-03-2003 07:20:06
Well got the hood off yesterday,Thanks to all it came off as mentioned.I have to drill out broken manifold bolts now.the manifold has a small hole on the exhaust side can I weld it?
CLARENCE
05-03-2003 22:41:13
SIR: REMOVE MEDDALLION UNDUE STERING BOX COVER AND REMOVE. REMOVE STERRING WHEEL AND TURN OUT, ALSO DISCONNECT THE LOVERS FROM LOVER CONTROL ARM, DISCONNECT GAS LINE FROM TANK AND POSSIBLE THROTTLE LINKGAGE, REMOVE BOTH SIDE GRILLS, DISCONNECT OIL AND TEMP LINES AND WIRING TO GENERATOR,NOTE GAS TANK COMES OUT ALONG WITH THE HOOD. GOOD LUCK, ALSO BUY A PARTS BOOK FOR THE TRACTOR AS IT IS A LIFESAVER FOR ME AT TIMES.
Dave K
05-03-2003 08:14:41
Buy the manuals!!!
will
05-03-2003 07:45:02
The medallion is the small piece of metal that has three bolts in it and connects the hood with the grilles. The steering cap is a round thing with two ears and two bolts to hold it on. Take out the two bolts, and just screw the long shaft out. It comes out the front. If your tractor is already restored watch the paint on hood while pulling it through the hole. If the steering wheel has been on for a while you will nearly have to get a puller, because it has a half moon key holding it on, and may have a little rust on it. Sometimes if they are rusted badly they require a little heat to help break it loose from the shaft.
Tony C
05-03-2003 07:29:08
Pull off medallion, pull steering wheel,take off cap on steering gear, turn out steering shaft. Tony
