70 Pony Distributor
Ron in CO
01-09-2004 16:28:55
What is the voltage supposed to be to the coils on the distributor and what is the resistance of the wire winding on the ignition switch? I'm only getting 1.5 volts to the distributor. Don't seem high enough to me.
F-I-T
01-10-2004 06:24:29
 Re: 70 Pony Distributor in reply to Ron in CO, 01-09-2004 16:28:55
Ron:
On the set I have in there now, they really start to misfire if the voltage is below 4.75. I've customized a resistor to yield right at 5 V. I get better spark that way. Maybe I just have a stubboorn set of coils, but I would think you'll need well over 4 1/2 volts to get it to fire right.
Frank
Brandon
01-09-2004 17:25:22
The resistor on my 80 dropped 6.36 volts to 4.13 volts. 1.5 is WAY too low. Perhaps you have a bad connection, or just a bad resistor.
Sorry, I don't know what the resistance in ohms is supposed to be. Magneeders sells new resistors, and mine works fine.
Good luck!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Ty
01-09-2004 19:47:43
 Re: Re: 70 Pony Distributor in reply to Brandon, 01-09-2004 17:25:22
My 70's are at 4.5v and work great.
