430 power steering fluid
Rod
05-02-2003 12:54:03
The cover on my 430 power steering says to use type A automatic trans fluid. Is that the same as jd power steering fluid or hydrallic oil or what? Never heard of type a. Thanks in advance
Ray
05-02-2003 19:52:28
 Re: 430 power steering fluid in reply to Rod , 05-02-2003 12:54:03
Oil has changed a lot since that tractor was built.I've found it best to use synthentic oil.
It will steer easier and not get as hot.
Henry J
05-02-2003 15:52:35
Rod
I use the cherry juice in my 420. I think GM just has come out with a new "better" type or designation. I am sure it will work.
Bguy
05-02-2003 13:30:12
Rod, I just went thru the same thing a couple of months ago, nobody had type A (which is the old GM type) and didn't even know what I was talking about. I got to reading the labels on what was on the shelf and in the small print it said it was compatible with Type A. I can't remember which one it was but just go back to the parts house and look at the labels closer. They all have it, it just goes under a different name know.
