Jd 60 tractor
david colonel
05-02-2003 11:01:02
problem. hydraulic fluid entering transmission when using three point hitch! anybody know why?
thank you .
david colonel
05-05-2003 19:33:38
 Re: jd 60 tractor in reply to david colonel, 05-02-2003 11:01:02
att. cole in mo,
gasket between rockshaft housing and cylinder replaced already. implement load stays raised,but oil still transfers to transmission when load repeatedly raised and lowered. any ideas?
cole in mo
05-03-2003 00:18:03
David, there is a seal in the back of the power-trol housing that is probly causing the problem. you have to remove the complete assembly to replace it. get a manual, it discribes what is involved. Its not that bad a job.
david
05-03-2003 09:01:00
 Re: Re: jd 60 tractor in reply to cole in mo, 05-03-2003 00:18:03
thank you very much
