Difference Between Standard And Row Crop ?
DAVID BROAD
05-16-2006 11:39:07
Hello . Have a question in Reguards to the 10 and 20 searies of the 1960s . As we are all well aware they came in two formats , standard and row crop . The standard of which , and do please correct me if I am wrong , was lower to the ground , the front axle turned around to give a shorter axle base , and wider , but smaller diamiter rear wheels . Bare in mind that that would affect the speeds , did each two formats have any different gearing in any way ? ie different difarentuals . Alos while we are on the subject . When the 30 searies came in , am I right in asuming that they and all successors right up to and including the 55 searies were only available in row crop form ? would be nterested to Know . Thnaks David [email protected]
JDBert
05-16-2006 14:09:14
 Re: Difference Between Standard And Row Crop ? in reply to DAVID BROAD , 05-16-2006 11:39:07
third party image
David- your wrong on the front axle- that would be a low profile utility set up like on a 3010-20 even a 40-4230 (very few built). Heres a pic of my 4020 standard- I've got the small rear fenders, you could also get them with the larger 5020 style fenders. It has a fixed front axe with 18.4x34 rears, BUT it's set up to go down 30" rows. I also have no three point. In the 10 and 20 series its more of a wheel/tire option the a actual "standard" option like on the 2 cyl.
Glen in TX
05-16-2006 13:15:58
I don't believe all of the smaller 10 and 20 series tractors were offered with standard tread options while larger ones were. Never saw a standard 2510 for example. Larger standard tractors like the 5010, 5020 and 6030 had standard tread options with shorter rear axles, wider rear tire options, HD cast non-adjustable standard tread front axle, wide rear fenders. Standards also had other options like no rockshaft or 3 point hitch, no PTO, and wide swing drawbar instead of regular drawbar setup. Many later 5020s and most 6030s were sold with wider rear axles, adjustable front end axle, 3 point hitch and PTO so the farmer could use them for row cropping also if wanted and gave the dealer options of selling it still for standard dryland wheatland farm use or selling also to a row crop farmer by just changing the tire options of wide or narrow. Only tire options would make the larger standard tractors lower to the ground and I don't recall there being any different gearing options either unless the smaller tractors had that. Some of the others can tell you about the smaller tractors. Never saw any of the larger 30 series on up with standard options except the 6030. Most all 6030s sold in this area were setup with rowcrop axles set for 80" for 40" rows and Hinson cabs with the narrow fenders.
