Hey Scruffy, First of all God Bless ya for what youre doing and may He help you through regarding your health. On removing such a tight bolt, if you have an air impact wrench, first be sure and use a good 6 point socket so you dont round the hex and if its adjustable torque or you can lower your air pressure input, I would start at not too much presure or force and let it vibrate her a while, gradually increasing the torque. If you dont have an impact wrench, I still think shocking blows and vibration is the answer as opposed to a long leverage cheater on a wrench usign a dead pull. Again, use a 6 point socket and with it held tightly in and against the bolt, I would hammer the wrench end with good sharp heavy blows to try and get her free. I dont think any sort of penetrating oil is gonna get in there and help much, and if you have access to a torch, dont heat the bolt so much as that softens it, but (in theory at least if you could get to it) if you can get heat to the crank area surounding/embedding the threads, the expansion and contraction might do the trick, however, there should be a washer there and you cant really get to where you need it. If you do heat the bolt, let it cool before you go back to work so its not heat softened. Good blows on the bolt head can help shock it loose, but dont mess up the hex. God Bless, Ol John T Nordhoff in Indiana
