Hour Gauge
Tye
01-09-2004 15:25:16
I got my generator rebuilt today. The guy said it was completely worn out. He put all new guts in it and a new regulator in it for $182. Worth every cent if you ask me. I watched him rebuild the entire thing- it was pretty interesting to see. Thank you Clooney and others for all your help. I have a new question about an after market non- John Deere hours gauge. If I wanted to hook it up to a power source that only has electricity when the tractor is running, would I hook the hour gauge up to the generator? If I do, what post would I attach it to? Also, if I run the lights and the ammeter shows a negitive charge, would that mean the hour guage would stop working? One more thing, on my tractor, there's a silver push/pull knob that kills the electricity in the distributor to shut the tractor off. I can't attach the hour meter to the ignition/light knob becuase the only electricity that flows through that knob is when I have the lights on. Thank you to anyone who can help me here. Have a great evening! ---Tye
Clooney
01-10-2004 07:13:16
 Re: Hour Gauge in reply to Tye, 01-09-2004 15:25:16
Tye, the simple solution is to just wire the hour meter to the power wire going to the ignition coil.. Mind your polarity as your tractor's polarity is probably positive ground & most hour meters are built for a negative ground system.. With most aftermarket hour meters that means the red wire goes to ground & the black to power. [the above assumes a distributor & no dash resistor for the distributor]... If you are running a factory Wico distributor post back or measure the voltage at the distributor post..
~If you are using a magneto you will probably have to go with the oil pressure switch & run battery power to & through the oil pressure switch then on to the hour meter [mind your polarity again]
~There is one other option if you are running a magneto & that is to wire the negative lead of the hour meter [assumes positive ground tractor] to the [A] post on the generator & wire the other hour meter wire to the tractor ground.. That way the hour meter will work when the generators supplying power [most times it is running].. At a real slow idle the hour meter might not work [depends on the meter voltage requirement & generator's speed] but it will probably work most of the time & will record most of the time engine wear is taking place.. It's easy enough to try & if you are unhappy with the low RPM performance you can always go to the oil pressure switch..
[email protected]
ET
01-10-2004 05:03:21
I put one of those hour meters on my late model A a few years ago. I hooked it to the back of the ignition switch and it works fine. I grounded the positive side and hooked the negative terminal to the switch. I used the tachometer bracket that bolts to the end of the governor as a mounting bracket. The hour meter gauge set right in the hole in the end of the bracket with just a little fileing.
Ralph - WI
01-09-2004 20:10:13
I was looking at a Northern Hydralics catalog a while back. Seems to me they had a meter -single wire connection to the Switch(?) that displayed rpm when running and total time when not. I think they have an online catalog.
david val
01-09-2004 15:54:34
i don't know about generators, i think it may be problematic since there is no charge on low rpms. with alternators you can get voltage from the d+ terminal that have voltage whenever the alt. control light is off. a simple solution is to use a two pole normally-opened oil pressure switch, plumbed into the engine oil system (can be T'eed to the existing oil pressure switch/gauge).when the engine is running and oil pressure is up, it closes a (+) or (-) connection to the hour meter.
another possibility is to install a vibration hour meter that senses the vibration from the runnin engine on the dashboard. (not good for cab tractors or cars).
david
Tye
01-09-2004 16:01:26
 Re: Re: Hour Gauge in reply to david val, 01-09-2004 15:54:34
David, where can I get one of these two pole normally-opened oil pressure switches? That maybe a good idea. Where would the power for the hour meter come from? The battery? Thanks. --Tye
david val
01-10-2004 01:11:41
 Re: Re: Re: Hour Gauge in reply to Tye, 01-09-2004 16:01:26
if you have a fuse box, you can get voltage from one of the fuses (after the fuse) that is powered by the ignition switch (if there is any). otherwise, you can get it from any power connection under the dash. connect the hourmeter (+) terminal to the power source through an inline fuse (about 5 amps). connect the (-) terminal of the meter to one pole of the pressure switch, and ground to the other pole of the pressure switch.
david
Brandon
01-09-2004 17:30:47
Tye,
I got an two pole oil pressure switch from my local NAPA. Just give them a description of what you want, and what diameter of oil line you'll be going into. It was about $9 for mine with tax.
Good luck!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
Tye
01-09-2004 19:55:51
 Re: Re: Re: Re: Hour Gauge in reply to Brandon, 01-09-2004 17:30:47
Thanks Brandon, I think I'll pay our NAPA a visit on Monday. Have a good weekend.
F-I-T
01-10-2004 06:53:45
 Re: Re: Re: Re: Re: Hour Gauge in reply to Tye, 01-09-2004 19:55:51
third party image
If you use the Echlin OP-6610 oil pressure switch from NAPA, you'll get a normally open set of contacts, and a normally closed set. I think it closes at 3-5#. That way no matter how you decide to configure it, the switch will work.
That's how Deere originally wired them. They hooked the meter from the battery and then through an oil pressure switch. Engine stops, meter stops.
Frank
