Hydraulic oil
Wes
01-09-2004 14:49:06
Is it possible to use hyd. oil in a powr-trol instead of 30wt? In our older combines they say to use 30wt oil in the hydraulic system but we run Hyd. oil (hytran) and have never had a problem. Just wondering what would happen.
buckeye al
01-09-2004 18:09:13
 Re: Hydraulic oil in reply to Wes, 01-09-2004 14:49:06
Been using Hygard in my 70D fo a good many years. Seems happy with it & I con't have to worry 'bout contaminating the 4020's oil with a remote cyl mix up. I'll read back here later to see if those more knowelgeable than I recommend against such. Good question.
Tye
01-09-2004 16:05:42
That's a good question Wes, I 've also wondered the same thing. I run the 30wt recommended oil, but it would be nice to hear more suggestions from the others on what they think about this. Sure would save me all the worries if I could run just one type of oil/hi-tran.
37D
01-09-2004 15:58:59
I've used nothing but the "trans-draulic" type oils, (The same as used in New Generation tractors) in all my 2cyl tractors for many years. Works great & I don't have to worry about contaminating the oil in my newer tractors with motor oil if I lift a wagon with my "G" & later use a newer machine to do the same. Actually I also use the later oil in the transmission on my "pressed frame "B" with a #45 loader, makes it shift far easier in cold weather. So far has not caused any problems, but I don't take it to the field & work it hard hour after hour either.
