JD 4230
Ted
05-01-2003 19:06:56
How much would this tractor weigh with cab and loaded 18.4x38 tires? Need to haul it home. Is this equal to a 4020 for hp? Thanks
David from Kansas
05-02-2003 09:13:13
 Re: JD 4230 in reply to Ted, 05-01-2003 19:06:56
Ted, my son bought a used 4230 about 15 years ago for a round baler tractor and it has performed well. As you may or may not know, round baling gives a tractor a real physical beating, as ground speeds usually run from 5-8 mph, and some hay ground in our country is terribly rough. The way the cab has held up is what is truly amazing. The only mechanical problem that I can recall is that he (my son) had to repair the 2-speed power shift part of the tranny once. Something you might be concerned about is the fact that the 4230 is notorious for hard starting in cold weather. If you live in where you will be starting the tractor regularly in temps below 40 degrees, you would definitely need a block heater.
Overall, the 4230 is an excellent tractor, in my opinion.
David
Bill
05-01-2003 22:27:13
I would guess weight at about 13000 lbs, my 4020 naked weighs 9180 lbs,, bookwise 4230 is about 6 HP bigger, performance wise I cant really say, never owned one, Guys I know really liked them,,,,Bill
