420C
Norman
05-01-2003 18:35:37
How do you know when the tracts are tight enough?
We have had them off and need to set the tention.
Thanks , Norman
MIKE HANLEY
05-02-2003 05:03:35
 Re: 420C in reply to Norman, 05-01-2003 18:35:37
Accourding to JD's tect manual the springs should be 14 13/16" end to end inside the two washers. With the crawler on the ground so all the slack is on the top, put a straigth edge on top of the tracks. The 4 roller should have a 1 1/2" deep measured at the half way point. 5 roller tracke should have a deep of 7/8" to 1 1/8" measured half way between the sprocket and the top iderler.
Norman
05-02-2003 06:43:35
 Re: Re: 420C in reply to MIKE HANLEY, 05-02-2003 05:03:35
Thanks Mike
Norman
