Hi Chris, I just got in me and my 24 yo son went to the new Menards store in town then out to eat and had a couple adult beverages lol. Anyway, it sounds like you may be starving for fuel, assuming at least one of the mags was okay. 1) Open the drain cock at the bottom of the carbs bowl and see if a good pencil lead sized stream of gas runs out continuous. 2) If not, remove the fuel line from the carbs input and see if a good continuous stream of gas the size of the lines ID runs out. 3) If not, remove the glass sediment bowl and turn the fuel on and see if the 2 lil side holes run gas out continuous and strong to fill the glass bowl. 4) If not, you may have a restriction up inside the fuel inlet pipe or screen up inside the tank. (A common problem) You gotta have a good fuel flow out the carbs bottom which has to flow out the tank, into the sediment bowl, through the line, into and through the carbs side strainer, and then through the needle valve and seat to fill the bowl before she will run right. When it starts to die, does she black smoke and/or would choking keep her running longer????? ????? ????? ????? While it sounds like fuel starvation and not excess fuel, you may still wanna take a look at the choke butterfly plate for corerct operation and the air cleaners bottom bowl for water. Is the gas free of water????? ????? and fresh????? ????? ?? Have you tried to adjust the carbs top load and idle needles????? ?? I dont think thats the problem at all, but try openign them a bit just to see what happens. If the carb isnt venting properly, it can cause her to starve for fuel also. While it could be ignition related, Im thinking fuel starvation for now, so see how the fuel is flowing at all the points described above and that the gas has no water in it and you might take a look at the plugs and let me know what they look like. John T Nordhoff in Indiana
