How much disk will my b pull
Chris
05-01-2003 14:53:07
Ive got a 39b i just put rings in its just a stock engine. How big of a disk will it handle. I am in mid tennessee and we have good ole hard a$$ clay if you know what i mean. Thanks in advance. Also it will be a tandem disk. Thanks Chris
Stan - Florida
05-02-2003 08:14:41
 Re: How much disk will my b pull in reply to Chris, 05-01-2003 14:53:07
From the previous answers, there is a wide variety of experiences. To add mine, we pulled a 7' Blount disk with a floating drag behind our '41 B. The Blount was a lighter-built disk with smaller blades than the Deere KBA. It worked the old girl, and I think 2nd gear was about as fast as we could go. That B, along with a team of Percherons (and a lot of long days) put in about 170 acres of crops each year, mostly corn, soybeans, wheat, oats and hay.
Stan
Gary in TX
05-02-2003 07:04:28
My dad used a 6' Deere KBA disk with his without any problems and he also pulled a two disk(24" diameter disk) Deere 92 breaking plow with it. This tractor is on my restoring list right behind the H I"m working on right now. By the way both the H and the B are 41 models. Also dad always ran his B on gas.
Pat
05-02-2003 03:19:24
We pulled an 8' tandem disk with my '39 B in Kansas, but probably not in 3rd gear! I also drove a ton of miles with that combination disking down corn & milo ridges, before we would cultivate it the first time. My neck still twinges 40 years later from the death grip requied to keep the B on the ridges and turning my head around all the time to ensure I wasn't digging out the small plants.
CLW
05-01-2003 21:36:44
We pulled a 6ft tandem and an old tumble type stalk cutter with a 43 B many years ago. Third gear as best as I remember.
CLW
Kerry
05-01-2003 19:48:30
Iv'e got a 1955 50LP, should be pretty close to the same as your B, I pull a 6-1/2 ft disk no problem. If it's really digging I have to pull it in 3rd, if it's not pulling hard I can do 4th.
Kerry
Gomer
05-01-2003 15:08:08
Five feet of tandem disk will load up the "B".
Bill
05-01-2003 18:34:06
 Re: Re: How much disk will my b pull in reply to Gomer, 05-01-2003 15:08:08
I have the 49 B and it pulls a 6 foot drag disc no problem.
will
05-01-2003 20:07:35
 Re: Re: Re: How much disk will my b pull in reply to Bill, 05-01-2003 18:34:06
your 49 B is 5 more horspower than this 39 unless yours is a distillate. That would be the reason that you can pull a six foot while he can only pull a 5'.
