Help Clooney or John T or any body help with oil leak !!
Nelson claeysen
05-01-2003 06:06:07
oil is leaking out of the belt pulley on my 530,I think it may be hydraulic oil leaking into the engine crankcase,the dipstick reads high ,then i drain it off and it comes back up. The hydraulic oil level goes lower, but engine oil will no flame so i think its not gas,any ideas where its getting in and how to fix it, any help would be appreacated
Clooney
05-02-2003 02:30:55
 Re: help Clooney or John T or any body help with oil leak !! in reply to Nelson claeysen, 05-01-2003 06:06:07
Nelson, you will have find out EXACTLY what oil is entering the crankcase. If it is indeed hydraulic oil you probably have a leaking hydraulic pump internal seal. Does the hydraulic oil level go down when the hydraulics are turned off? [that will tell us a lot].
