'46 A with no oil pressure revisited
Bryan
04-30-2003 20:59:54
Well, I took off the crankcase cover and sure enough, the square oil pump drive coupler was broken. Dropping the oil pump was easy. It would have been easier, however, if my arms were another 4" longer! This may sound stupid, but I can't find this part in my parts book. Does anyone have an idea of what the JD part # is? Thanks for all the help with this, guys!
Jim N.
05-04-2003 12:13:02
 Re: '46 A with no oil pressure revisited in reply to Bryan, 04-30-2003 20:59:54
Just put a coupler in a B and the new one is built much stronger. It is round on the outside so there is more meat to it. Don't know if this is good or bad. Maybe a broken coupler is better than a broken something else.
Bob
05-01-2003 06:52:01
What condition is the oil pump in? There had to be a reason the coupler broke, so I'd look it all over reall good to make sure the rest of the assembly is up to snuff.
Bryan
05-01-2003 09:23:10
 Re: Re: '46 A with no oil pressure revisited in reply to Bob, 05-01-2003 06:52:01
I checked out the oil pump last night. It seems to be in great shape. I think that the breakage had something to do with the ocean of water in the bottom of the crankcase. I think that we turned the flywheel a couple of times in the past few years when the temperature was below freezing.
Pappy
04-30-2003 21:28:23
Part number is B 250 R for all models of styled "A", according to the scriptures.
Bryan
05-01-2003 05:04:52
 Re: Re: '46 A with no oil pressure revisited in reply to Pappy, 04-30-2003 21:28:23
Thanks Pappy! I used that number and found it in the book using the numerical index in the back. Call me blind! I'm going to order it today.
F-I-T
05-01-2003 05:48:39
 Re: Re: Re: '46 A with no oil pressure revisited in reply to Bryan, 05-01-2003 05:04:52
Bryan:
Don't feel bad man, I had to do the same thing. I would have never known where to look.
Good job Pappy !
Frank-in-Tallahassee
70D // 855
