4020 with powershift transmission creeping
Todd
04-30-2003 19:02:50
I have a 4020 with a powershift transmission that creeps when its in park. What do I need to do? About how much will it cost?
Thanks.
Ducknose Bob
05-04-2003 09:32:50
 Re: 4020 with powershift transmission creeping in reply to Todd, 04-30-2003 19:02:50
This is pretty common with Power Shifts. The plates in the clutch pack(s)are slightly warped from being overheated at one time, and are dragging from not being fully released.
SmallOps
05-02-2003 05:33:36
Todd, the JD "later 20" series tractors all love to work! As a consequence, they will make every effort, on their own, to move back to the field or down to the barn! The 4020's creep, you are observing, is likely caused by this quirky tendency!
You have to be extremely vigilant with the JD later 20 tractor series, because of this well known habit. Todd, watch your 4020 like a hawk!
I have a 1020 that I have to chain down due to its exuberence and single-mindedness regarding this "work all the time thing". I've loaded the "little Ute" down with power taxing implements and run the damn thing from sun up to sun down... but it does no good! I can't break the 1020's exoitic working habits! And I've quit trying.
Todd, the point is get use to the 4020 creeping. It will be followed shortly by shaking, whinning, and begging! Your 4020 will use any ploy, trick, or tactic to get back out there and work!
Of course, those replies dealing with mechancial advice might have some valid points.
Opps... I've got to go! I hear chains rattling out in the machine yard.
Jim B
05-01-2003 04:05:38
Todd,there is a cable that attaches to trans.control and goes to RH side of trans.The cable is binding,not pulling park pawl in probably.Jim B
