JD 302-G gas tank pressure
Steve Hall
04-30-2003 13:59:44
I have a 302 industrial which builds pressure in the gas tank. The cap is vented which I puchased from the dealer(made in Mexico) and I recently purchased another to try but after an hour or so it starts sputtering like a vapor lock. I'm not sure if the tractor is getting to hot causing the gas to boil or what!!! Help if you can the dealer doesn't seem to be able to figure it out. The radiator has been re-cored and has a slightly smaller capacity could this cause this problem? The tractor itself is not overheating. Thanks SH
