4020 Revving up
Bill
04-30-2003 12:30:23
While disking I noticed that the engine "revved" up for a few seconds and then back down. I stopped to check things over, thinking that it may be low in fuel. The fuel pump is "weeping" a little, but not terribly bad. Everything seemed fine. It still does this occassionally but not as often after I put some more fuel in. Could I have some water in the fuel causing this? I don't know what effect "over-revving" a diesel can have and don't want to cause any damage to the engine. The tractor is a '64 model.
g pop
05-01-2003 04:01:43
 Re: 4020 Revving up in reply to Bill, 04-30-2003 12:30:23
sounds to me your govn. ring ,in your injection pump is about to let go
Dan S.
04-30-2003 21:25:54
First change the fuel filters and try it out for a while to see what happens. If this does not help the injector pump is a reasonable look. You may also want, or need to have the injectors replaced. last resort if none of thses work might be the fuel transfer pump
jeff
04-30-2003 18:40:03
Bill, My 4020 did this a few years back. It would rev up at the worst of times. It's the injection pump. For $300 you should be able to have it rebuilt. best of luck
jeff
04-30-2003 18:39:25
jeff
05-01-2003 19:48:27
 Re: Re: 4020 Revving up in reply to jeff, 04-30-2003 18:39:25
Again, G pop is right. You don't want the governor ring to let loose. Have the pump repaired ASAP.
Bill
05-01-2003 20:35:51
 Re: Re: Re: 4020 Revving up in reply to jeff, 05-01-2003 19:48:27
Now you've got me curious. What would(could) happen if the gov. ring let go? Others have suggested that it may be the fuel filter/delivery, I take it you and G-Pop don't agree.?.
By the way, thanks for all the info so far.
will
05-02-2003 13:40:55
 Re: Re: Re: Re: 4020 Revving up in reply to Bill, 05-01-2003 20:35:51
Im not sure about the gov. ring, but you are lucky enough to have symptoms. When it finally breaks the engine will run as fast as it can unitil it blows up, and washes the cylinder walls. The only safe way to shut it down is to cut off the air. Cutting off the switch will do nothing for you and bogging it down is chancey. you always take a risk of tearing something up if it gets running too fast before you catch high gear and the brakes. Better have the pump fixed before you have an oversped engine. Ours has done it twice. once with my dad and once with me. He choked it down by starving it for air. It did it once to me. Luckily I was sitting still at an idle, It just ripped WFO and as soon as i realized what was happening I found high gear and the brakes. I thought this was just a freak thing, because this post the only other tractor I have ever heard of with the problem, and I happened to my tractor twice.
MPK
04-30-2003 16:22:20
First thing to check is the fuel filter. I have had this happen.
Billyiron
04-30-2003 16:01:31
ours did that , would sit even at an idle then go in orbit, had to rebuild fuel injector pump,,,,Billyiron
