John Deere 730 Thermostat
Colt Edin
04-29-2003 20:45:09
Hey!
I just put a new radiator core and a rebuilt water pump in my 730 because the core was shot and the water pump bearing was pretty noisy. Since I've got all of this stuff apart, I'm going to put in a new thermostat as well. You can get thermostats that fit the 730 that are set at 160 degrees, 180 degrees, and 195 degrees. Which temperature of thermostat do you recommend, and why?
Thanks a bunch!
Colt and family
G Taylor
04-30-2003 05:27:58
 Re: John Deere 730 Thermostat in reply to Colt Edin, 04-29-2003 20:45:09
195F. Burns fuel better, less condensation in oil, less lube oil washed off cylinder walls by raw fuel, higher thermal efficiency and longer engine life.
