Hey Clooney or anyone else. Bad leak behind flywheel
Matt
04-29-2003 19:36:10
I have a John Deere 70 and I have put a new spacer and new O-rings in the spacer but it still leaks bad. I can tell there is no oil coming from the gaskets. Any ideas on what is wrong.
Thanks, Matt
Clooney
04-30-2003 05:53:41
 Re: Hey Clooney or anyone else. Bad leak behind flywheel in reply to Matt, 04-29-2003 19:36:10
Matt, a few things could be wrong...
~You could have cut the new seal on the sharp crank splines when you installed it.
~Or the drain hole under the spacer could be plugged. [common] ~Or you have excess crankshaft end play.
~Or you have excess piston blow-by that's forcing the oil out.
~Or you have a worn L/H main bearing that's allowing more oil into the slinger area than it can handle. [common]
~OR a combination of the above...
