Is this a factory hole for ignition switch? (B)
Lynn Kasdorf -
01-09-2004 09:10:01
third party image
Here is the dash from my '47 B. It apparently was upgraded to coil/distributor at some point in its life.
I assume that this randomly placed hole was drilled by the former owner, and is not factory, right?
What is the proper location of the ignition switch hole?
Clooney
01-09-2004 16:45:58
 Re: Is this a factory hole for ignition switch? (B in reply to Lynn Kasdorf - Leesburg, , 01-09-2004 09:10:01
Lynn, no matter where that hole is it wouldn't be "factory" as the B didn't use a distributor or ignition switch in 1947.. The end cap was also changed in mid to late 47 so that could be a little different also..
~I guess I wouldn't worry too much about the hole placement,, but if you are I sent you a dash picture of a later B with a factory installed ignition switch..
~I finally got around to answering your E-Mail [sorry for the long delay but I just worked my way down to it]..
[email protected]
John T (e mailed it 2 u)
01-09-2004 10:41:38
Lynn, check your e mail, I just sent you a John Deere B Lamp & Wirign Diagram which shows a rear dash panel view of where the light and ignition switches would be located (looks like the light switch location is correct on yours). It shows the ignition switch in the center above the light switch and under the ammeters center, NOT on the lower side as your dash pictures hole is. I cant guarantee its accuracy however, but thats what it shows for a late B????
Unless you can plug that existing hole nicely and cut a new one in the center under the ammeter, I would be tempted to use the one you have, but Im not the Correct Police either lol and cant guaranteee the pic I sent you.
Good Luck n God Bless
John T
ChuckW
01-09-2004 10:31:54
I think you're right....that's where the factory key goes....how do you get it to stop now?????
01-09-2004 10:38:30
 Re: Re: Is this a factory hole for ignition switch in reply to ChuckW, 01-09-2004 10:31:54
"how do you get it to stop now"
...more like how do I get it to go!...
I'm just in the process of making it run for the first time. I'm presently rebuilding the carb. The wiring is all buggered up, and I plan to re-do from scratch with new wire.
Are you saying that this looks like the factory location of the switch? This tractor originally had a magneto apparently, so unless the magneto B's had a hole like this, this was drilled by the prev owner.
I plan to install a keyswitch, but I want it in the "right" position, and wonder if this is the right position or not.
