Hydraulic filters(Steve).
Don
04-29-2003 11:46:53
Hi steve, Just removed the hydraulic return filter & the transmission oil filter from my 310 backhoe.Not sure where to find the tubular filter with the screen inside.Thanks for any help(AGAIN), Don
Steve - IN
04-30-2003 03:45:56
 Re: Hydraulic filters(Steve). in reply to Don, 04-29-2003 11:46:53
Don,
Jonathan's description sounds right. It has to be behind and above the cannister filter.
Jonathan
04-29-2003 13:44:53
The suction screen is behind that short hose that connects the hydraulic filter base to the transmission case....you have to unbolt the filter base and remove that hose and the one above it....unscrew the fitting that is in the transmission case and the screen is in there.... drain the transmission first !!!
