JD 4 bottom plow
markct
04-29-2003 08:51:12
i have a just gotten a john deere 4 bottom plow which somone had let the shins wear down too far and it wore down the part behind it, i believe its called the frog, thats not much of a problem tho i plan to cut out some steel and form it to fit in there and weld and grind it back to its original shape, however i do need to get new shins and the other part that is below the moldboard, i think its called the share? i know it is a 14 inch plow but thats all, i dont see a model number anywheres on it, i have looked in a few different catalogs for parts and i see that they just list parts as john deere 14 inch plow, were most all the plows the same or am i missing something here? i need to get the parts but dont want to end up with the wrong ones, also where might i be able to find a set of coulters for this plow, mine are missing
