Reverser Module Only Producing Pressure From One Port
Anthony
04-28-2003 14:53:19
I have a reverser module on a 1010 model that is only producing the required pressure on one side "reverse." The other test port is not producing any pressure-which leads me to believe there is a clog or possibly a regulator problem. The pressure guage does jump when moving reverser lever to forward which makes me think the shift valve in the reverser is moving, but pressure is not being routed to the clutch plate.
Anyone having a similar problem or knowledge about what could be the problem in the reverser please help! Thanks-
Bob
04-29-2003 09:02:44
 Re: Reverser Module Only Producing Pressure From One Port in reply to Anthony, 04-28-2003 14:53:19
You may have lost a seal on your clutch apply piston on the forward side, dumping the pressure without appling the clutch.
Dan
04-29-2003 04:52:12
I think i have a similiar problem with my 1010. THe reverser works fine for say 30min. they you loose forward power, with reverse power staying strong.
