Best model to start with
Pat
04-27-2003 19:57:32
I am interested in getting purchasing a JD two cylinder tractor to "play" with. What model/year would be the best for a rookie to start out with? I know this could be a can of worms as eveyone has an opinion, however any help would be appreciated.
Dave 2N
04-29-2003 11:34:21
 Re: Best model to start with in reply to Pat, 04-27-2003 19:57:32
My experience (48 A, 50 B and 54 70) says start with a styled B. Easy to work on, parts plentiful and a neat tractor that is easy to haul.
I think the B's and the A's are the essence of what JD tractors are all about.
My $.02.
JDknut
04-29-2003 07:30:04
I'd go with the 420. It is easy to fix and get parts for, small enough to be at home on small or large properties, yet fair power and lots of torque, and it is versatile enough to do almost anything, with hydraulics, live PTO and 3PH. Good luck with your "green" venture. just my $0.02
Dave K (FL)
04-28-2003 11:25:07
Is everyone overlooking the H?? Best small tractor we had on the farm. Will rake hay, pull wagons, do chores, spread manure, generally a good tractor to have around. I believe ,however, they are starting to get a little pricy, many hobby farmers want them. I would say if not an H then a B would work fine.
Dave
Jeff
04-28-2003 22:44:24
 Re: Re: Best model to start with in reply to Dave K (FL), 04-28-2003 11:25:07
In my neck of the woods (southwest Iowa)an H will bring nearly double what a B will and alot harder to find parts for.
Jeff
04-28-2003 00:21:25
I think we're all going to agree here. A 41-46 B would be my recommendation too. Easy to haul with a car trailer and a 1/2 ton pickup. Probably the cheapest to buy and work on. Theres a pretty nice '51 B right here in town, straight been repainted at one time, runs good, going to need some rear tires someday - $1200. So you can pick them up resonable too.
Ralph
04-27-2003 22:46:52
Physically left the farm 50 years ago, mentally and occasionally physically I'm back there. Only the A and G ran at the correct speed according to my ear. As per following posts, B, 50 etc would be a good choice, since in general they saw less abuse. I was never very keen on Dubuque. One reason - helping an ailing neighbor hay - Mike would know the road, Highway 33 down to Cannon Valley (not much more than a single lane of asphalt) - Ron made the mistake of heading down with a small load of bales out of a NH S-77 behind an MT. As we came up with an empty wagon behind an A, Ron was doing some serious signaling with his arm that he needed to use most of the road. I suspect it took about a week before all of the oil in the engine found its way back to the pan.
Steve - IN
04-27-2003 21:09:48
Pat,
I tend to agree with Will P.
The models that were produced in the largest numbers "back then" are still the most plentiful now. Meanwhile, the demand has shifted to smaller models, like M's, 40's, 420's, etc. So you have a large supply relative to demand hanging out there -- prices drop as a result. If you really want to pay a premium for a "smaller" tractor, check the prices on 50 year old N series Fords. It's because the demand curve has shifted over the years, smaller tractors didn't sell as well then (with the exception of the N series) but are in greater demand now for hobby farming, keep in the garage type deals now. So, the best bang for the buck in 2 cyl. now is in the old "mid line" row crop tractors, like a late model B. They were produced in large numbers then, but are in demand is far less now. A late model B would be my preference if I were in your shoes.
You can find a B or a A or a 60 now that's still in decent "play" shape (meaning you don't have to devote a lot of "work" to make it run) for far less in relative prices than the less expensive models -back then- which command premium prices now.
That's my take on the current supply/demand situation. In personal practice, I have a JD 1020 3cyl utility, which is just a jewel, and have had it for over 20 years -- but my favorites to work on are my JD 60 and my Farmall H (the two models I first learned on). The 1020 can do as much or more work than the two old row crop tractors -- but there's a lot more fun to be had by working, or playing, with the old row crop tractors. My old guys still work, still get dirty, and if you call that "play", and you want a 2 cyl machine, then I suggest you go with a "mid line" tractor like a B, an A or a 60 (50's seem a bit pricey to me, and 20 or 30 series even more pricey). The old 2 cyl's seem to be designed and built to last forever, and most jobs you'd have on a 5,10,20,30, etc. acre hobby ranch/farm is childs play for them.
Good luck and have fun with whatever model you find and start a love affair with.
Steve
Will P
04-27-2003 20:15:50
My opinion would be an early styled B. Easy to work on. Find parts farly easy. Fairly cheap to buy. Light enough to haul with a half ton pickup truck.
My 2 cents.
Will P
