John Deere Green change
Fred Mills
04-27-2003 14:45:49
I understand there was a change in the John Deere green color. What year and with which models did this occur? Any info greatly appreciated.
Fred Mills
04-27-2003 19:47:43
 Re: John Deere Green change in reply to Fred Mills, 04-27-2003 14:45:49
Thanks for the info on John Deere green
Larry H
04-27-2003 18:56:51
When I first started the tractor gig, I was told the expert was Tom Lucht in Omaha. I contacted him and found that since it's inseption JD has used 5 different greens and yellows. Good and easy break points are 39 52 and for more infor you'll have to see him.
Mike
04-27-2003 18:37:00
I have been painting JD's since 1978 using only
paint from John Deere about 10 tractors over the years. I bet if you look close and not so close on some everyone is probably a differant shade. They always seemed to be using a differant formula.
