John Deere Model 48 Loader
Brad
04-27-2003 12:21:45
I am mounting a 48 loader on a row crop JD The loader was off a utility, I have the correct mounting brackets and the mount for the hyd. valve however I need the two rods to hook the levers to the valve. Does anyone have these or know where I can find them. Thanks Brad
G Taylor
04-29-2003 08:07:26
 Re: John Deere Model 48 Loader in reply to Brad, 04-27-2003 12:21:45
Are you back fititng a high pressure new generation 48 loader onto a low pressure two cylinder? Lifting power will be very limited. There where some 48's made with low pressure cylinders to back fit onto two cylinder if memory serves correctly.
Brad
04-29-2003 17:04:57
 Re: Re: John Deere Model 48 Loader in reply to G Taylor, 04-29-2003 08:07:26
Loader is off a JD 2020 mounting it on a JD 2510
Gary in TX
04-27-2003 13:59:26
Hey Brad
You might try calling the parts dept. at your local deere dealer and see if they are still available, if not it should be easy to make a couple of rods. You can either get some round rod stock and heat and bend ends on it or thread it and use those threaded end pieces that go on adjustable rods. The ends are like the ones that go on the clutch rod on a 2 cyl. deere there on the clutch pulley brake connection.
Hope this wasn't too confusing, I"m not haveing a very good day and feeling very depressed.
Brad
04-29-2003 17:07:56
 Re: Re: John Deere Model 48 Loader in reply to Gary in TX, 04-27-2003 13:59:26
Gary My dealer claims they are not available, I may need to make them up. Thanks
Gary in TX
04-29-2003 17:12:16
 Re: Re: Re: John Deere Model 48 Loader in reply to Brad, 04-29-2003 17:07:56
That will be your lowest cost way to go anyhow. No telling what they would run at the dealer. I have a 48 loader on my 4020 but I have a valve on the fender for the loader.
