36 B TRANSMISSION
MDM
04-26-2003 18:26:25
I WAS PUTTING NEW OIL IN THE REAR END/ TRANSMISSION OF MY 36 B TODAY AND WHEN I TURNED THE BELT PULLEY WITH TRACTOR IN GEAR I NOTICED THAT ONLY THE LEFT AXLE TURNED. I HAVE THE TRACTOR UP ON STANDS AWATING NEW TIRES. WHEN I TURN THE RIGHT AXLE BY HAND EVERYTHING TURNS FREE. ANY IDEAS?????
John T
04-26-2003 19:54:57
 Re: 36 B TRANSMISSION in reply to MDM, 04-26-2003 18:26:25
MDM, It sounds like normal differential action to me (spider gears working so you can make a turn with axles turning at different speeds), they didnt have differential lock feature back in them days to lock both axles together. John T
Ken C.
04-26-2003 19:51:31
If I understand what your saying there is no problem, the axle with the least resistance is going to turn unless you have positive traction, have someone hold the axle that is turning and the other one will turn.
MDM
04-27-2003 08:36:40
 Re: Re: 36 B TRANSMISSION in reply to Ken C., 04-26-2003 19:51:31
THANKS FOR THE REPLY, I HAD A COLD SHIVER GO DOWN MY BACK WHEN I SAW WHAT WAS HAPPENING, EVERYTHING INSIDE SEEMS TO BE OPERATING FINE. THANKS AGAIN
