3020 stuck in reverse
bill
04-24-2003 17:09:01
non power shift,any ideas?
DON
04-25-2003 14:59:51
 Re: 3020 stuck in reverse in reply to bill, 04-24-2003 17:09:01
Bill , has the reverse been ripping when you put it in gear? the 69 models didn't have syncronisers on reverse and if you been ripping it in gear the teeth on the shift coller are burred up and now its locked up. same thing with syncronisers. I had a fellow get stuck once with a 4010 and he was useing high reverse and he split the reverse gear and we took a torch to the field and cut the shaft into so we could pull it out of the mud and load it. best remove the cover and look and see. Hope this helps.Don
Ken G
04-24-2003 19:08:20
Why not disconnect the shift linkages and isolate the problem to the shifter or the tranny. If its the tranny, taking the floor pan off is 4 bolts and the tranny cover is about thirteen 3/8 bolts. You know which linkage moved when you move the shifter while in reverse, so see if you can unjamm the shifter or cam from the inside. Just a thought.
bill
04-24-2003 18:18:55
Need more info,does gear lever move, etc,,,,, Billyiron
bill
04-24-2003 18:22:48
 Re: Re: 3020 stuck in reverse in reply to bill, 04-24-2003 18:18:55
i get slight movement from the lever on the side of the tranny
Bill
04-24-2003 18:44:02
 Re: Re: Re: 3020 stuck in reverse in reply to bill, 04-24-2003 18:22:48
Im shooting in the dark, first I thought that one of the shifting rods had broke where it hooks to the bell crank, could be problem in dash area, binding etc,,The shift quadrants get pretty sloppy with years of use but never seen one stuck because of it, shift rods and bell cranks get wore, oblong holes etc, you say you get slight movement, is it stiff or sloppy,,,, billyiron
bill
04-24-2003 18:51:27
 Re: Re: Re: Re: 3020 stuck in reverse in reply to Bill, 04-24-2003 18:44:02
the shift handle is a little sloppy,but it's tight going into the tranny.
Bill
04-24-2003 18:58:52
 Re: Re: Re: Re: Re: 3020 stuck in reverse in reply to bill, 04-24-2003 18:51:27
Well about all this ole boy knows is what I already said,I wish I could help more,Theres some real talent on this site I think its gonna take a certified brain,Ill stick to my hammer and baling wire,,,Good Luck Billyiron
