JD M Heating Problem
Don
04-24-2003 15:41:31
Does anyone know what normal operating temp. should be for a JD M . This one is runing around 190 To 200 with air temp. at 70 and that is not working it just setting runing at a fast idle.
Timeing is ok- back flushed radiator- exterior of radiator is clean- fan & belt are good. Anyone have any thoughts on this Thanks Don
Clooney
04-24-2003 18:37:22
 Re: JD M Heating Problem in reply to Don, 04-24-2003 15:41:31
Don, the temp gages on the M are known to read incorrectly due to temp pick up placement. Stick a thermometer in the upper radiator tank & see what you are getting out of the engine....
Richard
04-24-2003 16:33:30
I understand that the M series did run as hot. I have worked my MT in a hot 90's day , hay work, brush hog work and my thermometer read over 200. As long as it doesn't boil over your good to go. I guess the John Deere thermal syphin cooling system always ran a little warm.
