5020 John Deere
Ricki
04-24-2003 00:06:57
I was wanting some information about when the 5020 started. What year and what is the the difference btween that and the other 20 tractors like the 4020... How hard is the synchro transmission to drive?
Handsome Jim
04-24-2003 17:21:55
 Re: 5020 John Deere in reply to Ricki, 04-24-2003 00:06:57
My dad traded one of his 4020s for a used 5020 in 1970 because he thought we could use a bigger horse to plow some of 'black' ground. One thing about it, the 5020 was a horse but it wasn't very versatile for our application. It's weight and low slung stature made it impractical for our semi mounted plows and mounted chisel plows. In '72, he traded it for a 4620. Much nicer. As far as the Syncro Range transmission, it removed all temptation from shifting on the fly under a load and subsequently, lessened the chance of shelling out a rear end or tranny. not such a bad idea after all. HJ
Lyle (Sask)
04-24-2003 09:35:14
Hi, Never had the chance to run a 5020, but grew up on the seats of my dad's 4020's on the farm.
The synchro transmission is great for most field work. The trick when operating it is to remember shift on the fly in a range, and take the time to come to a stop when switching ranges.
Eg. 2nd gear to 5th gear is an easy shift, moving down to 4 and 7 takes a bit of careful work on the clutch if you want to do it while moving.
The primary use of the 5020 will probably be in the field hooked on a plow or cultivator, with that in mind, just grab the right gear and go...
If you need a bit of power to pull through a soft spot, remember that that model of tractor had a button on the throttle that let you rev it up past the 2200 or 2300 default rev limit...
Just pull the button out, and then pull the throttle down to get a few extra rpm when required.
I remember spending the whole day running one of our 4020's with the button out while pulling disk seeder in a wet spring... It pulled like a champ, and smoked a bit heading up each hill..
The synchro transmission was better able to get the engine power to the ground, the power shift while nice for loader work tended to soak up a bit of HP in the field work side.
We thankfully had one tractor with each tranny, and both were pretty darned reliable.
If your looking at getting a 5020, make sure you invest in some good hearing protection, cause those tractors were anything but quiet to operate.
I blame my selective hearing problem (according to the wife) on the 4020's.
David from Kansas
04-24-2003 08:03:07
Well, according to the "Big Book of John Deere Tractors", 1966-1972. However, I've been told my 5020 is a 1965???. During it's period, the 5020 was boasted as the world's largest row-crop tractor, tested in Nebraska at 141.34 PTO and 116.4 drawbar hp, compared to the 4020 at 91 PTO hp. The synchro tranny is real simple once you have used it a time or two. The 5020 was available in a row-crop and a standard version. (Only the standard version was available in the first year of production.) I do a little farming with a 5020 and a 4020. The 4020 is a power shift and is mostly used as a loader tractor.
