JD2020 left brake leaking off
roger c
04-23-2003 18:48:09
Been working on the left brake on my JD2020. When holding pressure on pedal, brake leaks off. Replaced o-rings in valve body assembly under pedals and 2 o-rings in rear end housing. What else could it be?
Jim B
04-24-2003 05:01:20
 Re: JD2020 left brake leaking off in reply to roger c, 04-23-2003 18:48:09
Roger,it could be the equalizer valve in the brake valve.If you lock pedals together will both pedals go down?If not will both wheels hold?Jim B
roger c
04-24-2003 07:45:36
 Re: Re: JD2020 left brake leaking off in reply to Jim B, 04-24-2003 05:01:20
The locking lever is missing on the brake pedals, but if you push both pedals at once, it does not bleed off. If you push the left brake only, it will momemtarily lock the left tire up, but if you keep pressure applied it bleeds off. The right brake works great. Thanks
Steve - IN
04-23-2003 19:41:45
roger,
I think there's a convuluted bend of tubing that snakes under the tractor to come up on the left side for the brake. Have you checked that brake line? I replaced that same line about two years ago on my 1020, so that's my first thought.
