Brakes on a JD 401B Yellow Tractor'
Heavy Hank
04-23-2003 11:36:05
I had to replace both external brake lines after I ran up on some rocks here is South Texas. They were smashed and split open. After replacing the lines and refilling the transmission with fluid, the brakes still don't work. How do you bleed the brakes when the brakes are internal?
John
04-23-2003 13:08:31
 Re: Brakes on a JD 401B Yellow Tractor' in reply to Heavy Hank, 04-23-2003 11:36:05
There is a bleeder on top of each axle housing where it abutts the differential housing. Attach a piece of quarter inch plastic hose to it and runit back to the hydraulic filler hole or a bucket. Then just bleed it like any other hydraulic brake.
Heavy Hank
04-23-2003 11:38:33
The JD 401B "Yellow Tractor" is the same as a model 2020.
cannonball
04-24-2003 06:06:40
 Re: Re: Brakes on a JD 401B Yellow Tractor' in reply to Heavy Hank, 04-23-2003 11:38:33
try a 2440 the 401b i have is same as 2440 except heavy front end..i think they make a heavy 2440..have nice day may god bless
