720D piston Rings
Randy@OKLA
04-21-2003 21:54:02
can anyone tell me where the ring gaps should be positioned on piston when putting piston back in?
F-I-T
04-22-2003 05:45:35
 Re: 720D piston Rings in reply to Randy@OKLA, 04-21-2003 21:54:02
Randy:
Make sure you check the ring end gap, too. Some of those rings can be a little long, and if so, when you heat it up you could have major damage.
Frank-in-Tallahassee
70D // 855
G-MAN
04-22-2003 04:52:33
I don't think there is any specific place in the cylinder bore to space them, but make sure they are offset ring to ring. I would stagger them at least 90 degrees from each other.
Randy
04-22-2003 15:13:32
 Re: Re: 720D piston Rings in reply to G-MAN, 04-22-2003 04:52:33
Thanks for input to all
