Front weights
Henry
04-21-2003 19:54:47
I have 2 front weights for the front of a tractor. they are L shaped and bolt on the side of a frame. there is no place to bolt on more slabs on front. Part #is A4828R , A4829R. the most of the weight is in the front of the tractor. they weight about 80-90 # each. what size tractor do they fit? what are they worth ? thank you for your help
donwisc
04-21-2003 22:03:10
 Re: front weights in reply to Henry, 04-21-2003 19:54:47
Your part numbers show up for a model 70 which means they should fit the 50 and 60 also. I also have a set of these and they will bolt up to the 20 and 30 series also.
I had them on my 730 and I actually like them better from a looks standpoint than the weights orig speced for the 20 and 30 series. I paid 300.00 for mine and it appears this is reasonable from a buyers point of view.
Dean A. Van Peursem
04-22-2003 21:35:37
 Re: Re: front weights in reply to donwisc, 04-21-2003 22:03:10
These two piece weights will fit the 60 and 70 but not the 50. JD made a different set of two piece weights specifically for the 50.
