720D timing
matthew
04-21-2003 19:09:17
Over the weekend I tried to verify the timing on my 720D. No particular reason other than I like to know things are right (runs good and smokes a lot less than most I've seen). Upon removing the flywheel cover, I found a pretty roughed up surface on the casting where my manual indicates the timing mark would be (I found the marks on the flywheel). How it came to be dinged and scratched in that area for 6 or 8 inches I may never know. Anyhow, after inspecting using great detail, I found one particular mark that I convinced myself was more defined and oriented better than others. But, before moving anything I checked the timing as is and found my timing late by this mark (none of the other marks matched either). Before I messed up, I thought I would ask for input. The mark I found is directly toward the front of the tractor almost exactly level with the center of the crankshaft. The other possible marks are several inches higher above a plane level with the center of the flywheel. I saw no real candidates lower. Does this sound right?
ps. If necessary, I can find TDC of left cylinder, identify that mark on the flywheel and go from there.
thanks for your input.
tks
Gordon
04-22-2003 18:02:01
 Re: 720D timing in reply to matthew, 04-21-2003 19:09:17
The ring gear can be put on in any postion.There are two marks on flywheel one for #1 and one for #2.If it starts good runs good leave alone if missed timed you can wreck pump just by turning engine by hand. It should start to inject before tdc read book.
matthew
04-22-2003 20:11:39
 Re: Re: 720D timing in reply to Gordon, 04-22-2003 18:02:01
Gordon, I'm not very good about leaving stuff alone. It is not my nature. Anyway, I found the mark for both cylinders easy enough. The stationary mark was in hiding due to a little rough treatment at some time in the past.
I read the manual and was careful not to touch anything warned against unless special tools were available. Intrestingly enough, my manual warned that pump damage could occur if the timing were set so that the mark on the pump went out of sight when the flywheel was turned 90 degrees from the match marks which is exactly how I found mine before I touched anything.
With the new found confidence from the first response, I felt good about moving it. Could have been my lucky day, but afterwards the tractor cranked immediatly and had very little smoke (less than before I think). I did not get to work it hard, but as I moved the injection timing earlier, I am guessing it will pull at least as good as before.
If there is something otheres can learn, I would like to pass it along. Don't turn the flywheel backwards even for small adjustments to align timing marks. The apparent backlash gave me a slight but detectable misalignment when I went around 720 deg to verify. After I figured out what may be happening and made sure I only turned the flywheel forward, everything became very stable. Thanks for the help.
GT
04-22-2003 18:21:18
Gordon; What does the ring gear position have to do with the pump timing? That ring gear has nothing to do with the pump or injector timing on the 720d. The timing marks are on the flywheel not the ring gear/
F-I-T
04-21-2003 20:03:24
third party image
Matthew:
I think the mark is the same for a 720D as it is on my 70D. The mark is indeed pretty much on the horizontal centerline of the crankshaft. Also, there is a hole for the flywheel cover at about 8 o'clock. Count 10 teeth up from this and the mark ought to be there. If you need better photos, I can get you some tomorrow.
Frank-in-Tallahassee
70D // 855
matthew
04-22-2003 03:23:14
 Re: Re: 720D timing in reply to F-I-T, 04-21-2003 20:03:24
thanks, that is perfect. I appreciate the help.
