620 carb still leaks gas , now what?
Mike F
01-08-2004 18:03:40
My 620 carb is still leaking gas out of the load stem, I put a new o-ring on and still leaks, can I put an o-ring on the very bottom of the stem, or does anybody have any ideas on this one? thanks in advance.
David Bacon
01-11-2004 19:55:20
 Re: 620 carb still leaks gas , now what? in reply to Mike F, 01-08-2004 18:03:40
Did you check the bowl--many are bent inward, usually this makes a far outside of bowl leak, easaly mistaken for your problem? Just a guess! Dacve NE Iowa
ET
01-09-2004 06:59:45
If there are any rust pits at all in the bottom of the bowel where the gasket sets it is hard to stop the leak. I have had some luck puting a small amount of anarobic plastic gasket maker on the bottom of the bowel where the gasket sets. I use the stuff for sealing the two halfs of a 2-cycle engine base. Gas doesn't seem to bother it if you let it dry real good.
Clooney
01-08-2004 18:51:19
Mike, are you sure you don't have a leaking bowl nut or bowl nut gasket?... Remember the bowl nut gasket goes inside between the bowl & stem.. I also use a second gasket on the outside between the bowl nut & bottom of the bowl as a second seal but you probably don't really need that..
[email protected]
mike f
01-09-2004 07:24:31
 Re: Re: 620 carb still leaks gas , now what? in reply to Clooney , 01-08-2004 18:51:19
Yeah I have the gaskets on the inside and outside, still leaks, appears to come out of the stem.
