3010 oil cooler
Mike
04-21-2003 09:41:40
Can an oil leak in the oil cooler in front of the radiater on a 3010 be successfully repaired?
Rodney A. Johnson
04-22-2003 08:09:38
 Re: 3010 oil cooler in reply to Mike, 04-21-2003 09:41:40
I would think any shop that fixes radiators, fuel tanks, or other low pressure systems using brazing or soldering techniques should be able to do it. If I recall correctly the hydraulic cooling radiator is not under high pressure.
In fact, I have a 3020 extra hydraulic coupler on my 3010 and one of the steel lines supplying the coupler (also from 3020) has been brazed. It has not leaked yet, and I have a 46A (with hydraulic bucket) loader I use off and on so the hydraulics get abused a little bit.
