Clutch puller
O'Neil
04-21-2003 09:10:04
I'd like for some of you more experienced mechanics to advise me on the best way to pull the clutch bolt at the bottom, so I can replace the pivot bushing in the hand clutch on a 70-730. thanks
Woody (NE)
04-22-2003 19:20:54
 Re: Clutch puller in reply to O'Neil, 04-21-2003 09:10:04
I used an 8" c clamp and a socket from my 3/4" set that fit over the head of the bolt. The bolt slides into the cavity of the socket. I loostened the nut a little and placed the fixed end of the clamp on the nut. The screw end of the clamp went over the socket. I sprayed with PB Blaster and tightened the clamp as much as it would take. I tapped and sprayed a little and the bolt started to move. Once it started, it came right out. Good luck.
Mike Aylward
04-21-2003 10:37:23
O'Neil, I make the pullers used to pull these bolts. They are a heavy duty unit and work very well. The price is $25 plus shipping. Mike
tw
04-21-2003 20:54:31
 Re: Re: Clutch puller in reply to Mike Aylward, 04-21-2003 10:37:23
This is a moderated discussion board. No Advertising of any kind is allowed here. This includes For-Sale and Wanted-To-Buy items. Use the classified ads page for these
Ralph
04-21-2003 10:49:44
Mike, Will your puller work on the styled AR, which has a different and less accessible mounting? I will be starting on the AR sometime in the next year.
Mike Aylward
04-21-2003 20:13:01
 Re: Re: Re: Clutch puller in reply to Ralph, 04-21-2003 10:49:44
Ralph, it should work, but if you can give me the measurements on all sides of your tractor's pivot bolt I can tell you for certain. Mike
Clooney
04-21-2003 09:25:02
O'Neil, the safest & probably the best way is to buy or make a puller that has a hole to go over the back side of the pivot bolt & another piece of steel that actually pushes the bolt end through. DO NOT hammer on that bolt or you risk breaking that ear off the 1st reduction cover [many have been broken]. ~You can make your own using 2 pieces of 3/8" X 2.5" x 6" steel strap & drilling a hole in the center on one piece that will fit over the bolt head & a hole in each piece near the ends so some all-thread can be inserted & tightened.
